1 - 14 of 14 Posts
i have a r33 gtst and i need to correct my front camber...which is better to get:
Cusco Pillow Ball Upper Mount
or
Cusco Negative Camber Upper A Arms
thanks for the help!!
www.spmcarclub.com
be intrested to read the replies on this one, ithought even with pillowballs on the front the front was still not camber adjustable
Discussion Starter · #4 ·
this is what i was told on another forum:
You have double wishbone front suspension so adjustable strut tops are useless, they're to suit Silvias and other cars with Macpherson struts.
You'd need the adjustable upper arm, but you should probably look into adjustable bushes if you dont intend on heavy track work.
SK's groupbuy has them and I'd say they're cheaper than the Cusco arms.
Whiteline camber kit would be my choice, cheap and easy to fit, can be done in situ if the old bushes come out easy enough.
As has been said adjustable top mounts will not work with this type of suspension,you need modified arms.
Forum loiterer!
I think i saw somewhere that the whiteline bush kits will only get up to 0.75 degrees adjustment, so if this is enough to get the camber angle you want these will be fine.
Discussion Starter · #8 ·
roger that...i need more than .75 adjustment...cusco here i cum
Cusco adjustable upper arms have 4 stages of adjustment ( fixed) I believe its -15mm -10mm -5mm 0mm and + 5mm
The only option to reduce camber being the +5mm
this is from memory though
Discussion Starter · #10 ·
Thanks Guys,
I found these but I don't know the differences...please help:
Cusco Adjustable Front Upper Links
OR
hi
sorry to dig up an old thread
i've got the +5mm cusco negative upper A arm shipping and on the way
i was under the assumption that this would give me more negative camber
am I right or did i just buy something that is not right?
how does the offset of the cusco arms work for -5mm 0mm and +5mm ??
1 - 14 of 14 Posts
