OK Guys and Girls,
This is being re-listed, due to the buyer having to pull out... blown clutch in his motor means money has to go elsewhere.
Everyone who knows skylines and knows RSP / Duno Tuner knows about this upgrade package. It has seen less than 10k miles in over 3 years and is in great condition.
This is being sold as a kit so that it is basically plug and play / well bolt on, plug and play. On the car it came from this was making 427hp and 355ftlb torque @ 1.2bar boost, enough to make anyones jaw ache from all the smiling and giggling they will experience each time they plant their right foot.
The kit consists of:
Priced at £1000 + P&P this is the a bargain for someone to bolt on 400+hp!
Things you should know:
This came off a spec 1 car, so not sure if it will be plug and play for spec 2 owners, you will need to contact RSP / Dyno tuner to find out.
There is no play in the turbo, it doesn't smoke or whine it is a solid Garrett unit, not a cheap eBay job!
Things you will need before installing:
So if you have a stage 1 car and want to upgrade, this is perfect for you. Any questions please ask. Just do not ask me to consider offers on the kit. It is priced to sell already!
Thank you for your time, pictures are attached.
- Z32 AFM + Plug
- Custom Remaped ECU for the kit
- RSP400 Stage 3 RB25 Hybrid Turbo ( 21U Exhaust housing - With oil line and adjustable actuator)
- Sard 550cc Injectors in rail, complete with FPR and loom
- An uprated clutch
- Walbro or Similar 255lph fuel pump
- FMIC Kit
- 3" exhaust from the elbow back and a decat
- Boost controller set to 1.2 bar
