Hi all,
The engine which I believe is code VQ35DE is it -
- muilt-point fuel injection or direct injection?
- is it variable valve timing?
Thanks.
DE has multi point, 1 injector per cylinder in the inlet port like most, and it had VVTI on just the inlet cam, the rev-up motor (rear in a 350GT) has VVTI on both inlet and exhaust like the later HR engine.
VE has multi point, 1 injector per cylinder in the inlet port like most, and it had VVTI on just the inlet cam, the rev-up motor (rear in a 350GT) has VVTI on both inlet and exhaust like the later HR engine.
Hi,
So what code is the engine in 2003-05 300gt as that's the years I'm looking for?
Thanks.
VQ35DE, as i said i have only heard of one 350GT with the rev-up motor in this country.
Hi,
So the 350gt has the VQ35DE engine so what type of fuel injection does it have muilt point or direct injection?
Sorry I'm confused because you answered about VE engine in post 2.
Sorry my mistake, edited to reflect the correct code now.
