1 - 3 of 3 Posts
Member
Hey all, having an issue on the R32 build, just fitted a FPR but after the pump primes the pressure drops instantly to '0' I have replace the one way check valve on the feed line from the pump and also replaced the FRP as I thought it might be faulty but even with the new one it drops instantly to '0' unless you clap the return line after prime it holds?
Any ideas?
Could be an injector stuck open or leaking around the seals.
I had that happen on an evo, fpr wouldn't rise with revs it dropped instead. Turned out the diaphragm was stuck, gave it a 10psi blast of air into the vacuum port and all worked fine after that. Might be worth a try, I had even fitted a new fpr to the evo and it was still at the same carryon until it met the compressor lol
1 - 3 of 3 Posts
