1 - 11 of 11 Posts
Hi all. Does anyone know what fuel pressure a standard fuel rail runs at using all standard parts? and also, if you install an adjustable fuel pressure regulator, what pressure can you run it at still using a standard fuel system? i know i should source a pump and some injectors but im poor atm. thanks for any replys :)
i have been told and read its 3 bar :)
the down side of running too much fuel pressure without mapping is massive over fueling on cold start, high fuel consumption and polished bores which will lead to ring failure and an oil burning/Smokey engine
Officer Hightower...
Jep, mine is overfuelling like hell, bad response on full throttle, fuel consumption don´t ask em, and on crossings, when I release the throttle to quick, the engine goes off....
Thanks for the answers!
1 - 11 of 11 Posts
