1 - 11 of 11 Posts
Why not? As long as you do the earthing mod to insure the pump is running on full song I don´t see why not. However you could use a GTR pump too! Of course only if you´re not planning on upping the power of the RB26 by a lot...
... is modifying the driver
recomended highly did this on a frinds 33t and work wonders.
You gotta give the Walbro pump a direct earth to chassis as it needs stable voltage to run on full song. The stock earth is controlled by the ECU and the Walbro pump does not like that. Easy job though. ;)
1 - 11 of 11 Posts
