I want to go for big hp and want to know the best (but cost effective) way to feed the beast, I was thinking of bosch 044 and swirl pot but i thin that is going to cos ttoo much for now. I then found this...
"This is the popular Bosch Motorsports "044" fuel pump, as used by Japanese European & Australian tuner shops, JGTC cars, Touring cars, almost all WRC cars, and many more. Quite possibly, the most popular aftermarket fuel pump. Capable of providing 300 LPH free flow and 200 LPH at 5 bar (or 72.5 psi) for up to 685 BHP. In comparison, the Walbro GSS341 255 "high pressure" fuel pump can support 390 BHP Note: Values calculated at 12V, 3 bar (43.5 psi) base fuel pressure, 2 bar (29 psi) boost pressure, 1:1 fuel pressure regulator ratio. These are inline fuel pumps, we recommend they be installed between the factory (or another aftermarket) in-tank fuel pump, and the fuel rail. These may be installed in the fuel tank, but some custom fabrication will usually be required. In addition, feeding these inline pumps with another pump (in series), will boost the output of the Bosch 044 fuel pump even higher."
does this mean I can leave the standard pump in and just wire this in series as well? has anyone done this as I have not heard of it before but would be much simpler (I know not as good as running a swirl pot but will be a road car so swirl pot could be over kill anyway)
thoughts and opinions gratefully accepted.
