1 - 20 of 37 Posts
After breaking my R33 GTS-T i find myself with a a few bits left over i now need out the way so i can get another car in the garage, up for grabs is the following items;
ANY OFFER CONSIDERED on all items looking to clear this stuff out quick.
Large FMIC no pipe work, no leaks, £40 collected, will post if needed.
3" HKS downpipe for low mount turbo £110 posted
BMC bm44, £40 posted
Front Calipers £110 posted, will post if needed.
Front upper OEM control arms/camber arms with 1yr old poly bushings £50 for the pair posted.
ABS pump £90 posted.
Rear strut brace OEM, £50 posted.
S1 Rear spoiler in Matte black with tinted brake light £40 collected, will post if needed.
OEM j-pipe £25 posted
Front uprights Refurbed by conceptua almost new with poly bushes £280 for the pair collected.
S1 bumper bar cut to take inter-cooler £25 collected.
Rear lights good condition £40 each posted or £70 the pair.
OEM Recirc valve £15 posted.
Pair of almost new (300 miles) 245x35x18 92y Falken Azenis fk453 £200 for the pair posted.
Walbro Fuel pump about 10K miles old £50 posted.
Rear sub frame stripped down and bushes removed ready for new ones £50 collected.
Front Sub frame £50 collected.
S2 Dash good condition. £80 collected.
steering rack £60 posted.
Down pipe for low mount turbo 3" to 2x2" to 3" unsure of the brand it was fitted by previous owner for stage1, £50
boot lid good condition, £50 collected
Rear half of ABS/Manual prop £40 collected
Doors £40 each collected
Photo's available on request.
I have a few other bits like switches, heater matrix, airbags and motors etc left over also PM if you need a specific part
Shell with V5 stripped bare (Sold)
S2 spoiler in silver without brake light. (Sold)
Blitz turbo timer with harness, (sold)
Toyo straight through exhaust no holes but needs a clean, (sold)
Rear Calipers (Sold)
Clutch and brake pedal (Sold)
Clutch master cylinder with clutch loop (Sold)
Pair 25mm hubcentric spacers. (Sold)
Discussion Starter #11
Sorry to be a pain did you have any of the rust and is it s1 or 2 thank you
Sent from my SM-G901F using Tapatalk
I cut the rust out and welded in new metal but rather then shape the arch's i just put over fenders on and blended them in, there is a small spot of rust on the drivers side strut top near the front can bee seen in the pic. is a S2 Shell, though I believe the S1 & S2 shells are the same it's the bits that bolt on that are different.
Here are some pics i took of the rust, the repair and what it looked like after i had finished.
Doesn't look like a bad job. Where are you located, also I'd that front bumper available too.
Discussion Starter #14
I'm in Aveley Essex (RM15) about 5 mins off the Dartford crossing.
sorry the front bumper is gone i took great pleasure in smashing it up, as it spent more time off the car being repaired and resprayed (due to scraping on everything) then it did on the car.
Yeah I front ended my car so debating on doing a re-shell or putting a front end on
1 - 20 of 37 Posts
