1 - 16 of 16 Posts
only just bought it but when i was enquiring about buying this i also enquired about something else but got no reply so i bought this, now this has arrived i have had a reply about the other thing i asked about and im quiet taken too it but will only buy it if this sells, if this doesnt i will keep it. jamie
£200
£15 delivery or collect from ashbourne, derbyshire
Discussion Starter · #7 ·
these any good? whats the pro`s and con`s on this unit?
dose it fit ok?
come with gaskets?
what throttle body do you use with it?
im unsure there is any cons with this unit but the pro's are things along the lines of better airflow, easier to pipe a front mounted intercooler with alot less pipework, makes you engine look 100 times better, ask a few others im sure they will list loads more pro's
it fits spot on
it unfortunatly doesnt come with gaskets (thats how i recieved it)
and most people tend to use a q45 throttle bodie i do believe
jamie
q45 throttle body? what did they come on? (300zx?)
how much would the inlet gasket cost?
is it hard to swap?
do the standerd injectors and rail and the idle controll all bolt direct with no modifaction?
will the standerd throttle body bolt on?
1 - 16 of 16 Posts
