1 - 14 of 14 Posts
Hi all, sorry if the questions come up before but can't find the answer by searching . Whats the oil capacity for the gearbox oil on a R33 Gtst (1996) please?
just under four litres afaik
im not sure. just get four litres to be safe. you can fill up the 32 gtst the same as the 33. but to make it even easier. find out the amount you need. drain old oil, remove gearstick and fill up through that hole :)
you can either fill it from the side so you can watch the level or like i said if you know how much to put in remove the gearstick and fill through there :)
I was told the R33 box took 4.1ltrs but when i changed mine, i never needed to open the fifth bottle (the oil came in 1ltr bottles) as four was enough.
Man of many spanners
R32 gearbox is the same as r33 n/a 2.5 litres.
R33 gtst is between 3.8 and 4.1 litres depending on where you find the info.
Easiest way to fill the box is by taking out the gear lever.
Pull out ashtray. take out screw and undo *** lighter electrics.
Take off cover. Undo big circlip and take out gear lever gently.
Takes about ten minutes.
Also if you have a bit of a crunchy gearbox try the nissan gearbox oil
KE916-99932 75w80 gl4+
Yeah I know its gl4 and you think you need gl5 but you dont!
i had a crunchy gearbox for the last two bloody years used redline heavy duty and motul stuff for rough gearboxes ,refurbed the clutch master cylinder, etc etc nothing....put this oil in a fortnight ago and the gearbox is sweet. all for £6 odd a litre:bigthumb:
1 - 14 of 14 Posts
