1 - 11 of 11 Posts
I'm just after sum ball park figures for the Duty cycle/Boost pressure and the Gain/Responce on this controller for when i plug it in to run at 1.2 BAR.
Trying to save abit of time on the setting up as the weathers not great at the minute for "testing". Plus i can always adjust the duty cycle either way if getting to little/much boost pressure:D as each car is different.
Anyone with this controller and running the pressure i aim too, your figures would be very usefull too me:cheers:.........I have tried searching but nothing was coming up:disappointed:
Thanks Les
It's the IBC, silver one they do/did:D
Discussion Starter · #4 ·
:attention: Anybody have this controller and able to give some ball park settings??
Try this mate :)
Setting a Gizzmo IBC - The (VERY) Simple Guide
1) Fit Unit as per instructions
2) Start car and allow engine to warm up thoroughly whilst doing the next few steps
3) Press the top button on the IBC until the no. "1" is shown on the display. It will flash 3 things: "1(The boost level)", "Target Boost(whatever that is)", "0.00(Real time boost level)".
4) Press and hold the top button until a number (The "duty cycle") comes up on the screen. Set this to 10 (the minimum).
5) Leave the controller for 4-5 seconds and it will return to the "real time" boost level
6) Press and hold the bottom button until a number (The "gain") comes up on the screen. Set this to "0" for the moment. Leave for 4-5 seconds until it returns to the "real time" boost level.
7) Drive the car on full throttle in 3rd or 4th gear.
8) Pull over to the side of the road in a safe place, then either turn off the ignition then turn it back on again, OR, Press the top button once, then the bottom button once (this will put the controller into boost level 2, then back to 1 again). Either way you do this you will be informed what the highest stable boost pressure achieved was by way of the pressure flashing at you on the screen. This is the new "Target" boost. Let us say that this was 12.5psi and you would like to achieve 16psi.
9) Press and hold the top button again until the "Duty" comes up again. Increase this by 10. Then leave the controller for 4-5 seconds until it returns to the real time boost screen.
10) Repeat steps 7/8/9 until the boost level you require is achieved. If you get duty cycle over 50 and the boost level is not increasing, then you have either not plugged in the solenoid or you have not plumbed it in correctly! As it gets closer to the level you would like, only increase by small steps of, say, 5 at a time.
11) When you are happy with the pressure, press and hold the bottom button and enter the "Gain" setting menu. Gain is How hard/fast the boost is brought in. It should NEVER be higher than duty cycle. In fact we have found the best setting is below 10. If gain is too high the boost will either overshoot, or the maximum stable (Target) boost will increase every time you drive it!
12) Repeat steps 3-11 on boost levels 2, 3 and 4 to achieve the boost levels you require.
It's extremely simple to do and the controller gives consistent, steady results if this is followed.
Discussion Starter · #7 ·
Julio2906:cheers:
That will be printed off soon enough, thanks. Just got to find some time between working and a dry road to set it up now:)
Discussion Starter · #8 ·
Update;
Finally some dry roads and abit of time to plumb the selonoides together and get this thing set up :)
Thanks to those instructions above sat on the seat next to me:bigthumb: Julio and the booklet that came with it things are looking up....
After numerous runs and only getting upto 0.9-1.0bar i had to stop and go re-fuel.
At the moment i have;
* Duty cycle/boost pressure set at 60%
* Gain set at 5 (some have found best results with this set below 10, aslong as it's less than the duty/boost settings, should be fine)
Have to give it a long run on way to work tonight to see what peak boost this results in. I had a look on the lancer register and one owner was getting 1.3bar at 60%DUTY and 10% GAIN. Thinking im on the right tracks:boogy: still may need reducing a little though. Gota get this figured so a don't feel so:dunce: Hope it helps anyone else setting it up themselfs....
Discussion Starter · #11 ·
Now got Duty/#boost at 70% and Gain at 10% thats got me hitting 1.17Bar in the real world. Probibly fine adjust it later on when conditions allow but it was already getting silly fast:).
1 - 11 of 11 Posts
