im starting to think my car dont like dump valves ( bov) i had i blitz bov fitted to the car when i bought it and it never worked right and kept droping off boost so i sold it and just had the standard dv , i got the car to run fine was holding boost and flying ! now ive fitted a hks ssqv and it sounds wicked but ive lost some power at the high end of the rev range it seems to not have the same kick at high revs as it had before ?? i have noticed that if i keep it reving upto redline the last 1000 revs it picks up again and all the power is back ???
do you need to reset the ecu after fitting a dump valve ?? i didnt think you did ?
its not leaking ive checked all the gaskets and vac pipes are fine on and around it
i have adjusted the dump valve itself and that dont work , the screw is now turned right in now is that right ? as i thought it could be opening and coursing the prob :notworthy
anyone had any probs like this after fitting a dumpvalve
