i just got my steering aligment done on my r33 gtr but the car is still pulling to one side. also there seems to be a large rattle coming from the front right hand side suspension when braking. is there bushings on a top arm that might need replacing?? need help lads!! cheers
are you close to any skyline tuners/ garage's as i would recommend taking it to someone who deals with them day in day out and get them to give a look over on ramps.
Jammy Git
Well I was going to say change your tyres (front) as this is what caused my car to pull (worse after a track day).
However if your arms are shagged then this might very well be the problem.
Maybe is normal...
Hi. I'm new on this forum.
I believe that is normal to pull to one side, because the road isn't flat, it has a little bend for the water to flow to the side. This applies if your car pulls to left if you are driving on the left side of the road, and right for the right side of the road, and this is more visible when driving through town.
But there can be a technical problem too, so you should ask a mechanic.
Cristi
