After having a few requests on these ive decided to offer these as a group buy. Minimum of 5 names. Price will be an all in cost delivered to your door of £260. (Controllers will be ordered direct from greddy japan)
This group buy will fun for the month.
Heres what Greddy says about them
Features:
Built in Boost gauge (kPA or PSI)
2 preset setting(Lo. & Hi.) and 3rd timed Scramble boost setting
Set % - to increase boost
Gain % - wastegate response adjustment
Start Boost - inital boost response adjustment
large OLED Display, slim control unit, seperated sensor unit, 300kPa (43.5psi pressure sensor) Warning point, warning limiter, peak-hold/Last boost
Compatiable with both acuator style and external wastegate style turbo systems.
The new PRofec is compact, powerful and easy to use. The large OLED Display, with the simple two-button / rotary-dial control, make for intuitive operation. An ultra slim controller can display in digital, bar-graph, or graphical modes and can be rotated 180 degree for installation with the included adjustable mount or flush mounted. By separating the display and control unit in the driver’s compartment, from the engine compartment-mounted, waterproof, sensor unit, it makes installation straightforward. Only one thin harness is required to be routed through the firewall. The combination of the new 300kPa (43.5psi) integrated pressure sensor, the more compact solenoid valve and faster ECU processer, provide quicker response and the most stable boost curves yet. The PRofec also maintains popular features like, Lo, Hi, Scramble boost presets, last-boost display, peak-hold recall, warning alert and safety limiter.
List.
1.jimbor32
2.
3.
4.
5.
Features:
List.
1.jimbor32
2.
3.
4.
5.
