1 - 16 of 16 Posts
S
Guest
Hi everyone,
Here's the main spec for the KIS 600HP LM Spec we just got with pics:
LM Spec Tuning Specs
ENGINE: RB27DETT
Bore x Stroke 88mm x 73.7mm
Engine Capacity 2688cc
Compression 8.6:1
Boost 1.4 Bar
Power 600hp .
Cams Ind.: 264 @9.6mm Lift HKS
Exh: 272 @9.6mm HKS
Valves: HKS
Valve Guides: After market (cannot read makers name)
Head Gasket Metal 1.0mm
Pistons Wiseco 88mm Billet
Con Rods HKS H section
Crank KIS
Crank Bearings Nismo GR/A type
Oil Pump Jun Auto
Clutch OS Triple plate DSB type
Water Pump N1 type
Oil Cooler Nismo (KIS modified)
Turbine Single T45S A/R 0.84
Exhaust manifold KIS original
Exhaust System Apex dual system
Throttle Valve KIS SP50/6
Intercooler HKS
Radiator KIS Original
Injectors: 550cc x6
Airflow meter Z32 KIS modified
Air Cleaners HKS80 type
Modifications
Head combustion chambers and ports modified (response type)
Block Debured and polished R32 Hi power version.
Crank Balanced
Pistons modified and balanced
Oil Pan KIS original large capacity
Strainer modified
Valves polished
Valve seats changed
Lights: Xenon R33 late model original
Steering: Momo Air Bag type
Wheels Volk TE37 18” special order
Tires: Neova 265/35-18”
Brake Pads: Hi performance.
Gearbox Route 6 Close ratio modified
Suspension Potenza Hi deck Stabilizer GAB Front and Rear.
The car has been kept since new under a Nismo car cover, its in stunning nick!
Stuart
skylinesrus.com
:D :D :D :D
Looks real nice Stuart.
First time I've seen a Low mount single.
Whatever it's got in it I'm with eddie on this one.
:drool: I am guessing that is going to be WAY out of my budget! Best get playing the lottery...
Think we'll need a mop soon to wipe all our drool..... Thats my dreams sorted for tonight...!!!
:drool:
Oh my god what a spanking motor! One of the best!
Stuart i am sure that you will have no problems selling that whatsoever! Especially if you chuck in a free nismo oil cap to replace that plastic one. :D
S
Guest
Discussion Starter #13
Got to keep the car original you know! Think of the weight saving, plastic to metal!
Stuart
I vote you run it yourself Stuart as that would free up a rather tasty Silver number I believe...
lmfao never miss a trick mate well done.
1 - 16 of 16 Posts
