1 - 8 of 8 Posts
Hi chaps
I've seen them plenty of times and am considering a set for mine
Are there any rubbing issues to worry about?
I seem to recall a possible problem with the inner edge of the rim touching a part of the suspension
Thanks in advance
You DO get a rub on full lock, but literally 1cm of correction stops it :)
Thanks General.
So fine except on full lock then.
Does the bigger size and particularly the different offset bugger up steering feel or cause much in the way of tramlining etc?
You will tramline, only very slightly though. And standard nuts are fine, they're a straight swap :)
Good mate, you?
1 - 8 of 8 Posts
