Caravan man
Hi all, I have a Non turbo 4 door gts and am looking for coilovers to sharpen things up a bit and to lower them.
The qusetion is ... will gts-t/gtr suspension fit or are they differnet as when you look on websites they all seam to use generic pictures and never show the actual product !!!!! can anyone suggest some for my car....
GTST one's should fit but GTR one's are differant the fronts are shorter and the rears the mount at the bottom is differant , hope this helps
confused.com
right then gts4 ..
r33 ... the (stock) front dampers are the same fit ment as gtr, but are valved differently. (softer than gtr when comparing oem units)
the rear is gts. the bottom of the damper strut on an gts(t) and gts4 has an eye type fitment, the gtr has a fork.
if you have r32 i cant be as definitive as i haven't taken one of those apart.
gtst coilovers will fit the gts4 onthe front but you wont be able to use all the adjustment as they arent made to take account of the front driveshafts. (speedr33per fitted his gtst ones on mine as a trial and we discovered this)
so in short ...gtr front gts rear. for the r33.
