What air filter are you using? Do you still have the stock AFM on your car? Stock ecu? Did you check for ecu errors yet? I've also heard a bad CAS will let your car idle funky and die. What voltages are you getting on your gauges?
Im using a cone filter. I got the stock AMF and ECU.What air filter are you using? Do you still have the stock AFM on your car? Stock ecu? Did you check for ecu errors yet? I've also heard a bad CAS will let your car idle funky and die. What voltages are you getting on your gauges?
No, where do i do that?Have you set the TPS to the required voltage with throttle closed?
Have you checked the cold start valve/ choke.sorry for hijack , thanks tricky will check mine as that seems to have a mind of its own sometimes , not rough idling but just increases ( @ 1500 ) when sat still also thought was air leaks but nothing showed up yet
also on intial cold start goes to 1800 - 2000 which I can only guess is the choke
