1 - 3 of 3 Posts
Recently my RB25 has not been idling correctly, it started a few weeks ago, idled at 2k stable, so I removed idle air control valve and cleaned it, idled perfect again for a few days. Now the idle sits at 3k, and never drops. Any ideas would be brilliant as the car is fairly un-driveable at the moment, it has a full straight through from turbo back so it's way to loud idling at 3k. Any help would be greatly appreciated, thanks in advance. Car has also had coilpacks changed last week which made no difference
Sent from my SM-G955F using Tapatalk
If you do anything with the idle you will have to reset the tps.
They both work in sync.
I would also check for vacuum leaks, and do a boost leak test as this is good at finding air leaks.
Any idea how to reset the TPS please mate? TPS and air flow meter work in sync? Thanks the for the reply
1 - 3 of 3 Posts
