As you may imagine I havent had much experiance with skylines but I am quite a competent mechanic. I would have thought that the hubs would have the same size centre bearing and therefore if I can get some from a breaker then it would be a faily easy job. But thats if the centre bearings are the same size. Otherwise the whole front leg will need replacing and the rear sus' will as well?Yep, it can be done... But can be quite costly... Be better if you can do it yourself...
Thanks:40oz:it's exactly the same as pug 106 and saxo hubs. They come in a 3stud and 4stud pattern, and are always swapped to 4's as sourcing wheels is far easier just look around for some am sure someone on here cud help source them.
Put a wanted up or ask.... is it roadrunner not 100% sure
hope it helps
might aswell do an upgrade then? cheers mate. i didnt think of that.vini u'll also have to get discs as well as hubs buddy
Thats the job mate. Was it very hard to do the hubs?are you talking about switching from the 4 lug to the 5lug hubs???? if so i had to do that. my shell was the base model with the n/a motor. i have had to practically convert the whole car to gts-t. also, when you do the rear you have to leave the e-brake setup from the 4 lug because its a pain to switch it out for the other setup. it works the same. all i did was cut the brake dust cover so you dont have to remove everything. depends on how particular you want to be.
Not yet mate I dont get the car until the weekend. But as soon as I do then I will. Unless you are on about the 300ZX then yes mate heres one.vini sorry to hijack ur threads but do u have some close ups of ur wheels as i've just bought the same ones for my Gtst
Cheers Chris
