Hazard light only right blinking
146 Views 4 Replies 3 Participants Last post by  Jed99
Hello
I have an R32 and my problem when i press hazard light it only light the right turn signal not both
but when i turn the left turn signal by the turn signal switch it's working perfectly.
this car is beautiful headache and this the last problem so i hope someone can help me with it
Hello I have an R32 and my problem when i press hazard light it only light the right turn signal not both but when i turn the left turn signal by the turn signal switch it's working perfectly. this car is beautiful headache and this the last problem so i hope someone can help me with it
When u press the hazard does it blink on the cluster? If yes is it blink very fast? Secondly when you use the individual turn signal controls is the clicking sound and blinking happen very fast on the cluster?
Yes it's blinking in the cluster but not fast it's normal, when i press the hazard it's just blinking right in the cluster and also outside, not both
Hello! Disassemble the emergency light button and open it, taking care not to break the plastic. You probably have dirty contacts. Clean and reposition contacts better. Reassemble all and test it.
So inside the vehicle ut works but when you watch it on the out side the right light is not blinking right?
