The std nissan head bolts are fine for 500+ bhp, it's not a weak point on the rb engines, as for the hg the std is 0.9mm and is good over 450 bhp so really personally I wouldn't go for much thicker than 1.2 or 1.3mm other wise you could lose some off boost drivability,
Speak to your mapper,
I would also invest in an oil cooler as running the higher boost levels heats your oil to alot higher temps quicker and shortens it's life,
Brucem sells good kits
