1 - 17 of 17 Posts
Nice car!
The powerFC will masure DET and knock levels. That should give a pretty good indication as to how healthy the engine is.
Deffo do a full compression check before you buy though;)
Welcome to the club mate - Very nice car you got there :)
... is modifying the driver
Welcome
If you get the chance to drive the car hard through a few gears you should expect the knock levels to be below 50 and the water temp to max out at 80. Keep on eye on the oil pressure as well :D good luck
Discussion Starter · #15 ·
Hi guys and gals unfortunately I didn't get the car as something was not quite right with it! So I'm on the look out again, so if you can suggest any r33 skylines for sale for under £4500 it would be much appreciated. Cheers
1 - 17 of 17 Posts
