1 - 1 of 1 Posts
hi guys i had a problem with boost a while back when you put your foot down the boost would die then boost madly then die so on and on so i went to a tuner and they said it was caused by a misfire so i changed the plugs and its was all ok now ive fitted a fmic and the problem has come back ive changed the sparks again and the coil packs and cleaned the maf sensor think thats what its called and the idle control valve as that was sticking now i cant say if the fmic has caused thre problem as it may have been playing up before any ideas what it could be would be greatly appreciated chhers in advance dan
1 - 1 of 1 Posts
