Where can I get a converter or new dial face for my speedo, have searched the threads here to no avail?
Old Member
You will have to get a de-limiter/speed converter from Import solutions. A little electronic block which fixes to the back of the speedo and joins into some of the wiring, also supplied is a sticker which goes over the K.P.H. to read M.P.H. It's a bit fiddly,but it does the job. All assuming the speedo reads upto 180 K.P.H.
It's probably mechanical then. Where are you located? Is, say, Abbey Motorsport anywhere near you? Try calling one of the tuners/parts companies and getting one mail order or something
G
R32 speedo converter
Hi,
we can supply you on overnight service with a converter for your R32. Piece of cake to fit. £45+Vat & postage
You can order with C/card etc.
[email protected]
Stuart
skylinesrus.com:D :D :D
Discussion Starter · #7 ·
I'm at Abbey Tom. so will ask him and also tell him about you skyline!
£45 sounds good to me, his speedo seems to read to the equivalent of 120mph on his kph clock?
