1 - 8 of 8 Posts
Hi guys
Trying to find out if ABS unit on 200sx will work on R32 GTR.
Did a search for ABS 200sx and couldn't come uup with anythign useful.
Posted on here but haven't got any responses so far.
http://www.gtr.co.uk/forum/128720-help-abs-unit-200sx-work-r32.html
This is the query -
i'm struggling to find a replacement for my ABS unit.
R32 GTR.
This is the unit that came out of my car
i managed to source this from a 200sx (think it's the version with a CA engine, not SR20)
The part numbers are similar. Seems like a mechanical part number that's the same, and an "electrical part number" that's difference. I'm just guessing.
Visualy, the silver part is almost identical in all respects.
The black relay bits look a little bit different.
They both have 3 connectors, which look exactly the same, have the same number of pins. The wire colours are very similar though not identical.
The GTR part has some wires that are yellow, whereas on the SX part those same wires are a greenish type colour.
Anyways.. does anybody know if i can use the 200SX part in my car and if it will work? What modification is required to the SX part in order to use it in the R32 GTR??
Any help appreciated.
Thanks guyS.
Why dont ya just try it and see wat happens?
Not such a hot idea 'cos if it all goes wrong you could end up with no brakes.....
Are you friendly with your local Nissan dealer? Have you plugged the part numbers into FAST to try to work out the difference?
Adrian
He'll still have brakes, but if they are incompatible the ECU will disable the ABS put a light on the dash and revert the system to standard non ABS brakes.
mate ring Julian at Garage D he has like 50x pumps , just not one for my 97 spec 2 GTS .......LOL
Just quote him number off your old unit ... job done
Discussion Starter · #8 ·
Ok, this weekend i put the 200Sx ABS unit in the car. Haven't had time to test it out yet.. will post up here with an update on Wednesday.
Don't want to bin ABS.. car is in pristine original condition and trying to keep it that way.
Am going to see what happens with this first before ringing up Garage D.. The car is in Africa.. so shipping costs might be a bit dear to bring it down here. But thanks fo the contact, might use it as a last resort. Trying to get something from Australia in the meantime.
1 - 8 of 8 Posts
