1 - 2 of 2 Posts
Needs a self cleaning car
My new splitter looks gorgeous, but is a source of grief when combined with the Trust Dowmax springs. My ground clearance at the front is about 50mm, and when the new alloys go on, this will drop by 9mm due to the change in rolling diameter.
The only reason why the car is lowered is to keep the handling with the new 18x10's, as I was warned that just slapping 18x10's on would cause the handling to deteriorate.
I need to increase the ride height a bit. I know the Dowmax drop the car about 35mm, so I really nead an alternative spring set that only drops the car by 20mm. Any ideas, ladies & gentlemen?
Some quick advice would be good as the wheels have arrived and I'm itching to get them on the car.
Thanks in advance.
Jae.
Discussion Starter · #2 ·
Emergency over
Problem solved by Abbey. :D
1 - 2 of 2 Posts
