1 - 3 of 3 Posts
Hello all,
  • I have a 1996 R33 Gtst and I needed some help with the wiring with the airbag system. I installed a NRG quick release kit and it required me to take off the clock spring assy, so I'm trying to get some info on the wiresthar connect to the clock spring assy, I.e. which wire(s) are the airbag ones so I can tap in a resistor. Thanks!
Terry
Here is a good link that may tell you what you need to know
Thanks for the response, but I have seen that post. The problem is the clock spring stays on in that installation. I removed my clock spring so i'd have to tap into the wires that would've connected to the clocks spring assy, so that guide would for a lack of better terms be irrelevant.
1 - 3 of 3 Posts
