1 - 3 of 3 Posts
I have searched everywhere and tried just about any method i could just to get my crankshaft pulley out. The pulley is seized on. I've soaked it in pb blaster, that didn't help. I've used the 2 bolt puller but rather than pull, it yanked the bolts out and destroyed the 2 holes completely. Although reluctant, I then tried the 3 prong puller and it tore chunks out of my pulley. I used 2 pry bars but the thing still will not budge. I'm nearly out of options here, does anyone have other methods?
As you have already wrecked it have you tried heat and there is also a freeze spray a combination of the two may shift it other than that take a grinder to it.
  • Like
Reactions: Ronin_R32 and tww
1 - 3 of 3 Posts
