1 - 10 of 10 Posts
:attention: Ok, so I got my idle problem sorted with a second hand O2 meter. I've bought Greddy Profec B - spec II boost controller, now fitted along with new plugs and Walbro fuel pump, which should be all great, except;
Dyno plot shows everything fine up to about 3800rpm, then, it just dies off up to around 5200, then picks up again to about 7000 then what sounds like a backfire as it changes gear.
We have tried a few things, e.g Variable Cam Timer solenoid, but makes no difference, we are now at the stage where it is a process of elimination (which sound pricey!).
Can anyone give me any ideas? Anyone had similar experience and what did you do?
:feedback:
:cheers:
Cheers, will check that out Stusy.
or it may just be over fueling as this will happen when you start to tune without fitting a fuel computer or aftermarket ecu.
Thanks Ian, so is there any way of checking (before it costs me!) whether it is over-fueling or coil packs? Would it smell 'rich', i.e. I'd get smell petrol, or does over-fueling sound a certain way?
Any way I can I tell if it's coilpacks or over-fueling, anyone?
r32 gtr...old skool cool
put a multimeter over two of the contacts of the coilpack and if you get 0.9+ volts then there screwed (should be more like 0.6v)......i had this with mine and got some from OILMAN on this forum for a very good 299
there is a post somewere on here about how to check them or serch back through my post as ive mentioned it sometime ago but since forgot lol.
Brilliant thanks for that, I'll do a search!
1 - 10 of 10 Posts
