1 - 1 of 1 Posts
I had 2 sets of these made when my mot failed on the rear hicas ball joint was flapping about.
You need to remove the hicas bush from the hub carrier and replace with a poly bush. Then these will replace the end which seured onto the bush.
toe is still fully adjustable :thumbs:
the kit consists of 2 brackets, 2 bolts, and 2 nyloc nuts.
I have been running a set of these on my car for about a year now and they work very well.
Im after £75 delivered for the kit :thumbs:
1 - 1 of 1 Posts
