Well lads. I bought a R33 Skyline 2.5turbo there about a month ago but havin problems getin it Nct'd cause of high emissions. The car is standard with cat back exhaust, frount mount intercooler, and mushroom air filter.
I put it true nct 3 times and it failed.
First time Emissions
Low idle CO 6.73 vol% (above 0.50% fail)
High idle CO 6.18 vol% (above 0.30% fail)
Lambda: 0.83 (not between 0.97 and 1.03 fail)
HC 198ppm
I then changed the cat, changed the lambda sensor with another second hand one, and mixed dipetane with fuel and gave it a good drive!!!
Second Nct time Emissions where:
Low idle CO 4.39 vol% (above 0.50% fail)
High idle CO 2.97 vol% (above 0.30% fail)
Lambda: 0.91 (not between 0.97 and 1.03 fail)
HC 205ppm (above 200ppm fail)
I then replaced the lambda sensor with a new universal one!!!
Third Nct time Emissions where:
Low idle CO 3.21 vol% (above 0.50% fail)
High idle CO 4.71 vol% (above 0.30% fail)
Lambda: 0.86 (not between 0.97 and 1.03 fail)
HC 223ppm (above 200ppm fail)
The nct man said the lambda sensor reading was constatly going up and down .
So anyone any idea what could be causing these high emissions? Could the ecu be f**ked?????
HC 198ppm
