got a hks ssq bov that has a slight squeek and i can't seem to figure out what the problem is.i striped it and greesed the piston and it's still the same any advise will be welcome.
cheers dave
Free icecream
Are you sure it's the bov? How can you hear a slight squeek above the tssschhhhh?
Could try - remove the cover (4 allen studs i think, the rest are for show), remove the insert put the cover on and try it again. Does it still do it?
Hang on, I read it again. Is it a slight squeek instead of the tsssccchhhh??
Ignore me :) :rolleyes:
i'v taken it to bits and i'v figured out it is the plastic exit port as i removed this and the problem went.can't see any cracks on the plastic peice,and i tried to seal this in to position but still didn't work. i might try a few different exit port designs any suggestions?
Dirty Torquer
dont the HKS bov's give off a high pitch 'sqeek' anyway instead of the meaty sounding blast of air ready to rip your bumper off??
Discussion Starter · #5 ·
put it this way if it is working right it sounds **** so look for a for sale add for a hks bov.
