1 - 3 of 3 Posts
Forum Thug
There was one on mine until I had my e-manage fitted, and then Richard took it out as he said it was not needed. Thats all I can tell you sorry, I didnt have any problems while it was on there though.
Registered User
you should.t have one mate.the boost cut on the r33 gtst is 0.9 bar and the safe boost level is 0.8.if you wanted to run over 0.9 then it will need a remap which removes the boost cut.the only time you might use one is if you use a piggyback ecu and need to avoid boost cut but its not the best way.
1 - 3 of 3 Posts
