IIRC the bolt holes on the wing are 40mm apart, the other one you will have to work out when its on the car. I drilled and tapped the big bolt hole and put a nut on the other side to give it more strength. The bit that butts up to the master cylinder was made out of flat aluminium and dirlled and tapped.
