1 - 12 of 12 Posts
Hi guys
What do you use to clean up the headlights to clear them??
used G3 and cleaners but nothing seems to work??
G3 and elbow grease :D or G3 and a polisher, i did her fto lights the other day and they came up a treat, toothpaste also works :D
What is plast-x?? I'm sure your guys are winding me up Toothpaste?? But i'll try anything well post pics! ;)
plast-x is a maguires cleaner in north america... not sure if they would have it in the uk...
Toothpaste should work... Elbow grease will be the key though!
Toothpaste does work, i thought it was a wind up too when i asked a while ago :D
I ended up using toothpaste first, then some Meguires scratch-X and it worked a treat.
T Cut, but as with most of these abrasive type substances, I wouldnt leave it on to long. Also make sure you use a soft cloth and that there is no dirt on the lights, otherwise you will scratch up the lenses.
1 - 12 of 12 Posts
