1 - 20 of 26 Posts
R33 GTST Owner.
Had a search about and cant find the answer so does anybody know how much oil i will need?
I run a 13 row oil cooler and when i do a change with filter 5 litres.
Nurburgring 2009 cumon
Same as Bruce, I have only used 5 ltrs with a filter change and with oil cooler.
Teck Boy
Hi
Just changed my oil a few weeks ago 4.2 ltrs
mine takes 6 (im sure) i have a trust thing on the bottom of my sump think thats some kind of larger thing than standard tho
confused.com
standard its 4.5 for the manual and 5.2 for the auto ......acording to my wegine specs. aftermartket oild coolers take up more ....
confused.com
unless its an auto. yiu also gotta rmember it may need toping up with a few 100mils once run for while after a chage as the oil recrculates and get sintothe filter and other areas. ...typical oil change is around 200mils short of empty anyhow unless youre striping the engine and the sumps coming off.....
GTR has a bigger sump capacity to GTS. GTS is 4.2 litres if changing the oil filter too rising to 4.5 litres if using engine flush iirc
confused.com
1 - 20 of 26 Posts
