1 - 18 of 18 Posts
sorry im pretty newbie with these stuff, after taking out the cat what do i replace it with? Also will i be able to take it to the ordinary mechanics for this as i understand its illegal???
It needs replacing with a decat pipe, which is leterrally that, a piece of pipe with a flange on each end.
These are available from most of the dealers advertising on this forum, or privately if anyone has one spare..which I do have as it happens.
Prices vary, as does the quality, and it does need to be decent as it will have to be in and out every year for MOT, which is why I got ours from Abbey Motorsport.
PM me if interested
Aitch
Not if you get a set of metallic gaskets, again available from Abbey motorsports or virtually any of the specialist tuners advertising on here.
Aitch
is a high flow cat as effective as a decat pie?
arnt cars that are younger i.e 1995 onwards the only ones required to have CAT's for MOT's as my R32 never had one in but it was never questioned and still passed std emissions
Punch me.
they would have to check the exhaust gasses to see if they were in tolorance....i didnt think they had the tolorance in the book as they were never sold in the UK or europe?
(maybe that was just the 32?)
It is not illegial to run without a Cat. However, if your car doesnt hit the legal limits for make and year without the cat, then it is.
The MOT guys dont have a check for the CAT, they just check the emisions from the exhaust.
you can only go no cat j reg or before not l reg mate.
The standard cat on a Skyline is 500 density, sports cat's are available in 300 or 200 density. The lower the density the better the flow, but any lower than 200 and MOT's can be a problem, 200's are also more expensive than 300 density units..go figure as they have less in them! Abbey have a 200 density unit available to order..but you won't get much change out of £400, if any after delivery charges, but that's par for the course on these items if they are quality. No sports cat can possibly flow as much as a decat pipe, but with a bit of tweaking it's a safer bet for MOT's and roadside Vosa tests for later motors.
Aitch
Straight swap and the sensor is not required, it won't affect the ECU as it's "off" by default. So, if it's not fitted it won't have any input, and if it is fitted the chance of it activating in a decat pipe is zero, so again no input to the ECU. It's there to detect a cat which is blocking and getting hot as a result, a straight through pipe is not going to block or get overheated so no output from the sensor, ergo no input to the ECU.
Aitch
1 - 18 of 18 Posts
