1 - 10 of 10 Posts
Hi guys I just got some 5stud.hubs for my 33
And just wanting to know if I can.still.use stock calipers on the new discs
r33 de discs are 250mm for the 2.0 and 280mm for the 2.5 and the r33 gtst are 296mm so no ,but you could redrill your 4 stud discs and then use the de calipers
Drilling another hole in my na discs to make them.become 5 stud didn't think.thanks.possible unless iv missed read your post
you have to use one of the holes as a guide with a boltto hold the 4 stud and 5 stud discs together and line up the centre bore and drill 4 new holes in each disc
I have 5 stud conversion on my RB25DE. I'm currently using maxima (5 stud drilled and grooved) front discs with standard front calipers at mo. Though i have just got r32 gtr calipers and discs about to go on. The rears i'm using 200sx S13 drilled and grooved with 5 hole drilled for 5 stud pattern.
Hope that helps
Daz
1 - 10 of 10 Posts
