hi im new to this site and find it very good. i do need some help with my skyline and hopefully someone can help me. i have a skyline gts rb20de non turbo, its been converted to manual gearbox, and thats all thats been changed on it. the problem is the idling is quite random for example..when i first start it idles good on about 800rpm, after driving around town i stop at the lights, idle goes to 2000rpm plus. another thing is, when i lift my foot off the excellerator, as i change from 1st to 2nd, the revs dont come down in between changes. any help would be much appreciated, thanks for your time. im unsure how to reset ecu.
Gloucestershire Area Rep
I dont think by reseting the E.C.U would make it better tho,but if u want to reset the E.C.U just remove one of the battery leads.
It's a long shot... but check your accelerator regulator (in the engine bay). It may be tightly wound. If so, just unscrew it a little to relieve the pressure.
idle problem get a job then lol check under the bonnet give it a rev from there and see if it is returning propperly rules that out for starters then get a job oh and welcome to the mad house where you from bazgoku
Auxilury idle controll ??...the thing that causes up-down-up-down-up-down idle problem on the 2.5 engines. Try a search for how to clean it, always worth doing anyway. All the best in solving the problem. My throttle sometimes idles up to about 1500+ when it has no reason to, but im puting my problem down to plug and overfueling right now.
hey thanks alot everyone for your advice and will try them all out. im from wellington nz. can someone tell me where the accelerator regulator is? thanks again
