1 - 3 of 3 Posts
Hey guys, anyone selling an indicator stalk? The one on my R32 is flickering the high and low beams. I took it apart, and it seems like the spring failed, much would rather get another one.
Cause I'd really, really hate to add some random switch for high beam on my R32.
Yeah, that one is located in New Zealand, was hoping to have one sooner than that.
I ended up wiring a switch to it temporarily. For anyone else that is looking, on the bottom of the plug, there's two wires next to each other, one black, and one white. The white wire should provide a ground (so make sure you use your multimeter), but you'll tap the black and white wires, then when they connect they should turn on the high beams.
Keep in mind, this is the circuit for when you are pulling the stalk towards you, and will stay illuminated even with the light switch is off.
1 - 3 of 3 Posts
