1 - 2 of 2 Posts
Bullet Tooth Tony
seen a few sets for sale at the mo and am wondering if i was to put say 1000cc injectors it would cause problems ecu/fueling side
what size can u run up to without major problems etc ?
M's Factory
you can run whatever injector size you want and once its set up properly on the appropriate ecu it will just run as normal but run in very low % for efficiency for the injectors until you uprate everything else to catch them up.
1 - 2 of 2 Posts
