1 - 2 of 2 Posts
Dandy Highwayman
in that spirit here are some lessons i learnt recently;
you cant fix a gouged up damper rod with body filler, it will leak and it will cover everything in your wheel arch in oil
you cant use a regular UJ with an impact wrench without it exploding in yer face.
always allow enough time to do the job 3 times once to **** it up , once to fix it, once to check you fixed it right.
oh yeah, and the most important lesson is that you will never learn from your mistakes you are doomed to repeat them over and over again
1 - 2 of 2 Posts
