Folks,
My sincere apologies for bringing this up again but I do need your help. I have read a few posts on converting the jap audio visual stuff on GTs from jap to English but here in London, I am not clear if anyone actually does this?
Can you please point me in the right direct re-this conversion?
Many thanks
DB:)
As far as I'm aware although it's been done, there's no one currently doing this.
I think it ended up being more expensive so people just swapped the jap stuff out for new aftermarket.
I have Jap TV and have found how to link in via aux cable from jap TV tuner in boot.
So it is possible to run UK tv / DVDs / etc
It really depends on what you want to achieve
Many thanks Piranha. I just want audio visual system that I can relate to and understand. And if I have to change out the whole system, so be it...
I think changing it out is the best bet.
I have taught myself the jap buttons that I need to use for the basics but eventually I will swap out for aftermarket.
Be aware that the heater controls are part of the stock stereo surround.
Not sure if you plan to diy fit aftermarket,
I haven't tried it yet but some research I have done has led me to believe it's not a good idea to totally rip out the stock system because it's all interconnected to the canbus system.
So do some research before wading in.
Moved to the correct section!
And a search here will answer all your questions.
Thanks again Piranha.
FTO
Im holding out for a few months till a company here supposedly will have an English fix with NZ maps. Hope it works out.
Are english buttons still around? Yet to run into them.
