1 - 19 of 19 Posts
or front brake stabilser bar bushes
Could be discs as has been mentioned, also pads glazed or sticky pistons giving uneven pressure on the pads.
Best give the brakes an overhaul and check out the condtion of the parts then replace as necessary.
No one has mentioned it could just be the pads. Which is the cheepest option here. Had numerous cars that had major judder all cured by a decent set of pads. If you don't know what make you have on at the mo (if you have just got the car etc etc) might be worth going for something like redstuff.
Then if the judder is still there stick the old pads back on and keep the new pads for once the discs have been checked for being warped. If they do end up getting skimmed or you buy new ones you will have a set of new pads already and waiting :)
had same problem
i could feel the judder through the pedal and one of my discs was warped so changed them for some 3G Grooved discs mega improvement.
Regards, Thwish
Nissan Skyline r33 gts-t
mines also doing this fitted ebc grooved discs, shakes the steering wheel and full car when braking from 70mph?
is it my disc's or tension rods?
Most of the time warped discs get an uneven pattern of wear around them. Take a good look at them and try and see if you can see like a smearing sort of a pattern on them when you look at them from different angles if you get me.
1 - 19 of 19 Posts
