1 - 12 of 12 Posts
OK... Question time... (Again).
I am giving serious thought to chopping the belt that drives the aircon pump. What I want to know is..... (apart from the ac not working) will it do any harm?
Can it be easily removed without cutting?
And, most importantly, will I see any benefit in terms of performance?
ANyone done it?
M's Factory
remove the belt without the ac working and you wont notice too much of a difference. Anything to lessen the load on the engine on any of the belts is a good thing.
at the pod a lot of pro's take off the alternator and start the car via remotely.
The Ac pump is probably on a bracket which can be loosened and slid to then remove the belt easily I would have thought.
Bet its really sunny and chuffing humid the day after you do it.
I have seen a dyno sheet with the car run with full beam and the alternator drags quite a few horses off the power.
Take the AC pump right off and save quite a lot of kilo's too
Discussion Starter · #7 ·
Buster... Been thinking about dumping the whole lot (incl the AC radiator). Heard the whole kit weighs 20 Kilos... Now, thats about a quarter of me, so its quite a saving (half a tank of fuel, if you prefer almost).
Never had a car with air con before, and I've only switched it on about 3 times anyways so figure I won't miss it...
And as far as passenger comfort goes... F**k em!
Ah so the Buster philosophy is alive with you as well. Once the aircon head unit is out you have space for a load of gauges or the like. You can get light weight racing alternators and gel batterys as well. Demon tweeks race catalogue is a piece of motoring porn
Discussion Starter · #9 ·
Heh heh!
Well, I was gonna dump all the under bonnet crap, but not touch the dash unit. I presume if I dump the A/C system under the bonnet then I will still have heater/blower functionality and control?
My assumption is that they are independant systems. Got enough gauges etc in the dash these days to keep me happy!
Ut oh
Yep the heater will still work...i've removed everthing air con from my car and i'll tell ya the pumps an absolute [email protected] to remove....it was so much of a nightmare i paid someone else to take it off...:)
Ut oh
In the long run i rekon its worth removing but you won't really notice any differrence i think they work it out as every 10 kgs you remove from the car is equal to adding 1 bhp.
One thing i did notice is that when you rev the car there's a bit more engine movement on the mounts.
1 - 12 of 12 Posts
