1 - 14 of 14 Posts
lads
ive found my car to have a slight bit of lag before 4k then it just takes off like a rocket up the road , now i put an air filter on it and it mad the problem 10 times worse , the car just had a full trust exhaust inc decat and down pipe and also a trust panal filter thats it , i though at first it was the actuator sticking but its itd holding 0.5bar boost fine no drop at all ...so now im thinking mybe airflow meter ???
anyone have any idea?
rab :)
mine did this and it did turn out to be the afm.
yea ian im sorta thinking that as well
is there any way that u can throw up a fault code on theses cars ?
see if theres anyone near with decent coilpacks, splitfires!!! Ask if they can swap to check.... Should be ok with it... I loaned mine to sir nodrick and it was the coils....
So you will know wat to spend your dough on before you splash it all out and the problem hasnt been fixed....
with coil packs tho would it not jump on and off a pot? this is just lag its like your actator is open and not building any pressure ...hmmmm
im gona change the coils anyway to spitfire ones i think cos the nissans are wild for braking the oe ones
i got myself a blatz cable and datascan software which can read fault codes and show up to 12 different reading from the engine.
a right theres no way of making the car flash up the eml light a certain number of times ? then for example its flashes 5 times it mite be afm or 6 times would be tps and so on ?
Member No 48
Have you reset the ecu since you did the mods? If not, do it first before doing any fault diagnosis. The ecu needs to relearn your new engine settings now that you've freed up the breathing.
the cable and software are only around 70 quid from flea bay. looks good on the laptop as you drivealong :)
no didnt even think of doing that , never needed to do it on any other car that ive owned and honestly didnt think that made any difference doing that,surely your ecu has some sort of self learning ?
i will show you tomorrow old man :) need to do mine too
Member No 48
To reset the ecu...easy way.
1. Find yourself a nice quiet road preferably in the evening (air is cooler).
2. Stop car at side of road switch off ignition.
3. Disconnect positive battery lead from battery.
4. Sit in drivers seat and press brake pedal for 60 sec's (dissipates stored electrical energy in ecu).
5. Reconnect positive battery lead. (make sure the steering wheels are pointing straight ahead or it mucks up the hicas before you do this).
6. Start car and give it beans in the first three gears 3-4 times.
Your ecu will relearn your new settings.
mmmmmmm i was told different
3. dissconnect negative side
4. press brake pedal few times
5. reconnect battery lead
6. idle for ten mins, steady drive for ten mins then ten mins of bat out of hell
1 - 14 of 14 Posts
