1 - 13 of 13 Posts
on the plug that comes from the sensor it has 2 wires on it but the other one that comes from the loom has 3 wires the plug got pulled off and has a misfire can someone tell what wire goes where when the release tag is on top
You can just crimp or solder the wires, sensor types here..https://www.lambdasensor.com/main/skyline.htm
Try Aliexspress or Amazon for a plug.
But it wont be the sole cause of your misfire as you said it will clear up once run for a while...lambda feedback is used full time in lower loads/RPM and only stops after a certain load range and RPM is used so would return as soon as you where driving in traffic/cruse etc.
if i dont boot the car to hard its fine but when i boot it on full boost when i let off it starts to misfire and car seems to hit over 1.something boost think it was mapped to .9 could this be the problem that its overboosting
Discussion Starter #11
mate checked the wires and 2 wires in the wrong place so going to swap them around hopefully cure the problem
1 - 13 of 13 Posts
