Hello everybody,
Recently I got Skyline R33 GTST and already fixed common issues like a speedo, suspension ball joints, HICAS joints, air conditioner actuator etc.
At the moment I am having problem of leaking oil from the oil cooler. To fix that I already got new seals and O-rings, had already read service manual for my engine RB25DET.
Service manual says I need to remove only oil cooler ASSY including oil filter bracket and some coolant hoses.
But I steel not sure if it can be done in this way, because there is no space, all parts are very close to each other. Worst case I have to remove Inlet manifold.
Does anyone know how to remove oil cooler? It is necessary to remove Inlet manifold?
I need to fix it soon, any help would be great.
Thanks guys
Aleksej
Thanks guys
Aleksej
