1 - 10 of 10 Posts
· Premium Member
Link G4+ Plugin Group Buy
We have decided to do another group buy on the fantastic Link G4 plugin ecu for the RB engine. The Group buy will only go ahead once we have 5 or more people on the list. Once we have enough people we will take a deposit and can get you booked in.
The Group buy is for the following :-
Link G4+ Plugin ECU
Boost Control Solenoid
Cas Trigger wheel upgrade
Fitting of the ecu
Mapping on the Dyno and setting up of boost control etc
RB25 uses will also require a High speed Air temp sensor and boss and extension loom which we will do for a Extra £65 which includes the parts and removing the intake pipe and welding the boss to the pipework etc.
The vehicle will be needed for at least 2 days to allow for mapping and cold start mapping etc.
Price will be £1500 which is a saving of just over £250.
If your interested please put your name bellow and we can get the list started.
Feel free to ask any questions.
· Anglian Area Rep
Richy rich.
Does this fit my standard casing.
My car has one of your custom maps on and id like to sell that if I went this route. What's my options?
I'd also like to know does this include the launch control etc?
· Premium Member
Discussion Starter · #5 ·
Hi there,
Yes it fits into a standard the standard ecu casing. You will either need to supply a ecu for the case or I may have a old case laying around which I can sell you.
Yes I can also set the launch control up in that price based on vehicle speed as it requires no additional wiring etc.
Richard
· Registered
Will this work with a series 1 auto Stagea? I've read some posts which say you can piggyback the ecu with a link g4. (obviously depends on if you can do it regardless on if someone else could do it)
If the ECU will work and its something you can map I have a hybrid turbo from the old RSP400 kit, what else would I need to fit to the car to get around the 400 mark..
1 - 10 of 10 Posts
